Schmitt trigger low pass filter software version
Discussion in 'Homework Help' started by helloeveryone, Nov 27, 2013.
  1. helloeveryone
    Thread Starter Active Member
    Apr 8, 2011
    54
    Switch debouncing
    Slide 9 in this presentation:
    http://web.engr.oregonstate.edu/~traylor/ece473/lectures/debounce.pdf
    We can see that there is an upper threshold and a lower threshold.
    How many thresholds does a digital software low pass filter use?
    a) none
    b) one
    c) two
    d) multiple, depending on the application.
    I'm not really sure. A threshold just means "when you go above this level do this" or "when you go below this level do that". Couldn't we use none and just say 0 do this, top value reached do that.
  2. panic mode
    Oct 10, 2011
    1,328
    305
    slide 9 shows graph with 2 thresholds
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    If software is sampling an analog voltage (0 to 5V) wired to an ADC input, then you can program multiple thresholds or hysteresis, i.e. If V(in) > 3.25V Then X else Y.
    If the switch is wired to a logic port, then by definition, the signal is already a One or Zero, so all you do is "low-pass filtering" in the time domain... i.e. how long was it a One before it became a Zero, etc.
  4. ScottWang
    Aug 23, 2012
    4,929
    777
