Schmitt trigger and rectangular wave
Discussion in 'General Electronics Chat' started by CobelAli, Mar 14, 2013.
  1. CobelAli
    Mar 14, 2013
    Is it possible to produce a rectangular wave with a duty cycle of 10 percent using a Schmitt trigger and a constant frequency sine wave? I seem to recall the minimum duty cycle possible was 50%, but maybe that limit was for something else.
    Thanks,
    Ali
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    It is, but even if it were not you could make a 90% duty cycle and invert it. The duty cycle depends on the trigger levels, for a short duty cycle you get into the peaks of the wave and things get ticklish on exact values. It is also sensitive to the amplitude of the wave.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    Square up the sine wave to get 50% dc then use a retriggerable one shot to adjust for the dc of your choice. You might even get lucky and be able to skip the squarewave part of it.
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    To check is this suit your need?
