schematics for an automatic washing machine
Discussion in 'Homework Help' started by samrat, Apr 3, 2008.
  1. samrat
    Thread Starter Active Member
    Apr 2, 2008
    30
    Can someone point me into a site where I can find the schematics of a washing machine??I am doing a project on microcontrolled device and all that is left is the systems diagram and circuit schematics of the automatic washer...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That's a problem. Every manufacturer does it differently. What I would do is get the model number of a washer and look online for the electrical diagram (they don't really have schematics). The control board will be a black box, with inputs and outputs labeled, but no detail on the stuff inside.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Your best bet might be to look for an obsolete, or unsupported, unit and go direct to the original manufacturer. Ask them if they would be willing to give you conditional access to the said documents for educational purposes only. Companies are very cautious about releasing IP so it is a long shot, but I think it is your best chance at getting the information you require.
    Dave
  4. techroomt
    May 19, 2004
    198
    if you're referring to the general electrical schematic, they are often pasted on or inside the back cover, or in the literature received with the unit. otherwise as mentioned, just type the model number into google, and look at the responses for a schematic. you will likely find it. you will likely not find anything for inside controllers or other boxes as it is often proprietary.
  5. samrat
    Apr 2, 2008
    30
    Thanx fellas.
  6. loosewire
    Apr 25, 2008
    1,584
    435
    Go to radio shack, buy the how to use meters book they have diagrams
    of washing machine curcuits in back.
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  8. JoeJester
    Apr 26, 2005
    3,400
    1,218
