Schematic software for beginners
Discussion in 'General Electronics Chat' started by droggie, Dec 21, 2012.
  1. droggie
    Oct 21, 2012
    137
    I have recently begun using schematic and circuit simulator software. I find it has helped me understand schematics a lot better. I've been using the java circuit simulator linked below for sometime. The only problem is I cannot seem to save my schematics and it won't let me copy the code to MS Word.
    http://www.falstad.com/circuit.
    So does anyone have any suggestions for schematic and circuit simulator software? Something for beginners like myself; proprietary or freeware.
    Thanks,
  2. Veracohr
    Jan 3, 2011
    559
    77
    LTSPice from Linear Technology
  3. spinnaker
    Oct 29, 2009
    5,103
    1,190
    LTSpice is hardly for beginners.
    Not a circuit simulator but Express Schematic / PCB is very easy to use. Aslo I have been working with Diptrace lately. Harder to use than Express but more powerful and still not that hard to use.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    Many people here use LTSpice, and IMO, it is great for beginners. There is a tutorial on their site to help get you started. Plus, this is a great site to ask questions when you get stuck.
  5. droggie
    Oct 21, 2012
    137
    Can I ask where I find LEDs, voltage sources and transistors in LTspice? Or do I have to create them manually?
  6. spinnaker
    Oct 29, 2009
    5,103
    1,190
    Yes they are in there.
  7. droggie
    Oct 21, 2012
    137
    Sorry I found it. But now it says I have to flag it as ground a node as ground.
  8. spinnaker
    Oct 29, 2009
    5,103
    1,190
    Well do what it says and add a ground. It's right up there on the toolbar.
  9. Brownout
    Jan 10, 2012
    2,375
    998
    You should go through the tutorial. It covers all of this.
  10. droggie
    Oct 21, 2012
    137
    Seems pretty easy to grasp; although the simulator isn't very friendly. Thanks!
  11. droggie
    Oct 21, 2012
    137
    What is IMO's software site?
  12. Inquisitive
    Nov 12, 2011
    8
    9
    IMO = In My Opinion
  13. Veracohr
    Jan 3, 2011
    559
    77
    Is there really a simulator that is for beginners that is limited to simple concepts? A simulator is as simple or as complicated as the circuits one simulates with it.
    The most basic passive components are in a toolbar above the schematic area, and they should have pop-up flags saying what they are (in case you aren't familiar with all symbols). The one that says "Component" gives you a window that gives access to more components. Transistors are labeled npn, pnp, nmos, pmos, njf, pjf. After placing the component, you can choose an actual model rather than the ideal model that is initially placed. Voltage sources are the component 'voltage', and you can choose all sorts of characteristics of them. There's a folder for opamps which should be populated with LT-brand opamps, and at the end of the list there are some 'ideal' opamps. I use "UniversalOpamp2" all the time.
    You're right, it's not entirely intuitive for beginners, but just start simple and ask questions, and search the LTSpice User's Guide to find out all the various things you can define for a component. Some of it you might not be familiar with, but you don't have to define everything.
  14. spinnaker
    Oct 29, 2009
    5,103
    1,190
    Yenka for one. Not really very good as a real world simulator but it will teach the basics.
  15. tinkerman
    Member
    Jul 22, 2012
    136
    34
    Found LTSpice from this thread and started to play with it. Is there a way to flip SCR so that the gate is on the right instead of left side? Also is there UJT symbol? Haven't found it yet. If there is, angain can it be flipped left to right too?
    TIA
  16. Brownout
    Jan 10, 2012
    2,375
    998
    Yes, at the top, right of center, of the window, there are curly arrows. One flips the symbol in the x-direction, and the other in the y-direction. Use the 'hand' icon to grab the symbol, then click the arrow(s)
  17. tinkerman
    Member
    Jul 22, 2012
    136
    34
    No I found that but that's not what I meant. I would like the diode pointing downwards as it pops up would like the gate on the right. I don't see a way of changing that unless I'm missing something. I wonder why they choose Yahoo for users groups. :(
