Because pin 13 is now connected to pin 16, which is a 5.1V reference supply. Look at the datasheet, the output stage is supplied from pin 13, so if you don´t connect this pin to at least +10V you can´t use standard mosfets.If you supply pin 1 on the chip with 12V it will drive any normal N mosfet. Why do you say it will only drive a logic mosfet?
alternating between fully on (nearly 12V) and zeroSomething like this? http://www.pcsilencioso.com/cpemma/pwm.html
Lm324 has a max single supply voltage of 32V.
Ken
I plan to use IRF1405 x 4But the mosfet choice is limited to logic-level mosfets. Also I don´t like the D1-D2-R5 combination, I think that choosing a chip suited to driving a single mosfet would be better.
