http://vakits.com/sites/default/files/imagecache/product_full/LM324_0.JPG This is the op amp and I have connected to the + & - points and copied the schematic exactly. do the ground points on the audio outputs come straight from the ground rail on the op amp?Yes. They're not shown as they're the op amp power supply positive and negative rails. Imagine that there is a +v and -v connected to each op amp in the schematic. Use the data sheet for the op amp you are using to work out which pins these are. As there are 4x op amps in the package there will be one pair for all of them as 2 pins on the device.
Yes but only if you use AC coupling on the outputs in this case and block DC. Audio signals have no DC offset. Add a suitable capacitor between the output and the input of your next device depending on the frequency. It will attenuate the signal at certain frequencies (reactance of cap = 1/(2*pi*f*c)) so a larger capacitor i.e. 10/100uF will block DC here fine in the audio frequency range (things get a little more complicated after a couple of MHz).http://vakits.com/sites/default/files/imagecache/product_full/LM324_0.JPG This is the op amp and I have connected to the + & - points and copied the schematic exactly. do the ground points on the audio outputs come straight from the ground rail on the op amp?
Thank you Doozer, I'll try that out tomorrowYes but only if you use AC coupling on the outputs in this case and block DC. Audio signals have no DC offset. Add a suitable capacitor between the output and the input of your next device depending on the frequency. It will attenuate the signal at certain frequencies (reactance of cap = 1/(2*pi*f*c)) so a larger capacitor i.e. 10/100uF will block DC here fine in the audio frequency range (things get a little more complicated after a couple of MHz).
Also don't assume those are good audio outputs - they will swing close to the supply voltage which is going to be much larger and most "line level" audio inputs are expecting consumer level outputs so they will cause massive clipping without any attenuation. See: http://en.wikipedia.org/wiki/Line_level - you should probably add an attenuator (a potentiometer - 5/10k is usually fine - in a voltage divider arrangement between the output after the coupling capacitor I mentioned above.
You will probably be able to hear a wrong capacitor value as a muffled sounding output. Experiment with exact values if you need to. If the attenuator is set too high it will clip which sounds like a buzzing rather than a clean tone.
Should look like this on the output (excuse my mspaint skills - it's all I've got handy):
Don't worry about negative voltages for this. The LM324 doesn't need a negative supply. Some op amps do.
There's no virtual ground reference in any of the stages connected to an input (osc/integrators) and this is a single supply opamp so it will still operate as intended (I know, I built this about 25 years ago). As long as the supply voltage to the opamp allows for the outputs to swing far enough based on the stage gain without going near the rails (big issue with 324s) I.e. Vicmr isn't violated as you say. Now the integrators tend to attenuate rather than amplify anyway and the first osc doesn't matter as its saturated in each cycle so this isn't likely to be an issue. Maybe if this was a wein or twin-t network with feedback through an opamp."Don't worry about negative voltages for this. The LM324 doesn't need a negative supply."
Nope. The LM324 input stage common mode voltage range can extend slightly below the negative supply rail without introducing clipping into the output signal, but that does not mean that the chip doesn't need a negative supply any more than an LM741 (a class favorite around here) does need one. And for the TS circuit as drawn in post #1, there definitely needs to be a negative power supply voltage - negative with respect to the circuit reference potential. There are several ways to achieve this, and only one of then requires true split power supplies, but for almost any analog audio processing circuit there needs to be supply rail that is negative with respect to the circuit reference potential for the exact same reason that there needs to be a supply rail that is positive.
ak
