Hello All ,
Plz take a look at the schematic & PCB i have attached with this msg .
The schematic shows that the collector of PNP transistors are connected to the X connector & the base is connected to the 10K resistors .
Now according to the designed pcb , the Transistor's Collector is connected to 10K resistor & the Base is connected to the X connector .
Is it that the PCB is not correctly designed ?
Any comments will be deeply appreciated
Best regards
LUBNAAN.
Best regards
LUBNAAN.
