Maybe it's long winded, but given that there isn't any such thing as HHO (and I regularly see it posted as if it were a real molecule) I think I would loose it. It is causing more harm than good. H2 O2 is one more letter, I hesitate to call that long winded. My first contact was with Aqualine, and reading the articles and communicating with the "inventor" left me no doubt he/they were trying to say they had something new and unique, a new molecule, which just ain't so.
Then there is the issue of mislabeling a dangerous chemical mix. H2 O2 is EXPLOSIVE, and is plain not safe to be around in any quantity. I have no problem with generating it as needed, but one of the first lessons of Material Safety Data is proper labeling.
In short, the whole term HHO is misleading, and I believe it was meant to be so. Declaring it is not a chemical doesn't work, if you insist on using standard chemical convention to describe it.
This is just the latest stanza in a very old song, Brown's Gas was the first verse as far as I can tell. Beleive it or not they put this mix in high pressure gas cylinders, the same kind you get welding Argon and other high pressure gases. This practice was discontinued after a few explosions.
This material does have industrial uses, a little research will show that. But to claim special powers for it requires evidence, which has been notably nonspecific.
Tell you what, I'm going to repost this in your other thread, and discontinue this thread and use this thread instead. We've kind of drifted off topic anyhow. I won't post anything else here, so you can have the last word.
