Hi all,
I've seen a device that can create a modulated electrostatic field to transport sound through a human body. More details about this device can be found here: https://www.disneyresearch.com/project/ishin-den-shin/
The following is en exerpt from the text:
The only thing I know is I need a power source, a sound source (I will go with a prerecorded sound), an amplifier and basicly a wire connected to my skin. Could anyone of you help me with this project?
For one thing, I'm kinda scared of touching wires with 300V on them.
This amplification driver converts the sound loop into a high voltage, low current (~300 Vpp, ~50 mA) inaudible signal which is applied to the conductive metallic casing of the microphone via an additional connector. When holding the microphone, the visitor comes in contact with the inaudible, high voltage, low power version of the recorded sound. This creates a modulated electrostatic field around the person’s body. When touching and sliding hand on an object such this modulated electrostatic field creates a very small vibrations. As a result, both the finger and the object together form a speaker, that makes the signal audible.
I want to create a similar device to deliver a very import message to my relatives in a way that will blow them away (both message and delivery ). However I'm at a total loss on how to build this thing.
