Schematic Dusk to Dawn
Discussion in 'General Electronics Chat' started by spike1947, Apr 14, 2016.
  1. spike1947
    Feb 4, 2016
    39
    Hi
    Could anyone on here check out this schematic I have done, to see if it should / will work ! .
    cheers
    spike
  2. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi spike,
    I don't see an image.?
    Eric
    spike1947 likes this.
  3. spike1947
    Feb 4, 2016
    39
    Hi
    Sorry I don't know why it did not post ! .
    cheers
    spike
  4. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi spike.
    What is the images file name extension and its size.?
    E
  5. spike1947
    Feb 4, 2016
    39
    Hi E
    Have uploaded into my first post ( edited ) .
    cheers
    spike
  6. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi spike,
    I may be wrong but I believe that non isolated mains circuits contravenes AAC site T&C's.????
    E
  7. Dodgydave
    Jun 22, 2012
    5,171
    778
    The thyristor will turn on when the ldr resistance increases as the daylight reduces, depending on the Vgk of the thyristor, usually 1.5v. Note the output voltage will be half wave 120v pulsed dc, i would use a Bridge Rectifier instead of a single diode.
  8. spike1947
    Feb 4, 2016
    39
    Hi E
    It is only a excerise to see if that circuit works , if I was to put it to use I would of course enclose / encase / isolate it from human touch to IP 5/6 , but off course I can just delete the thread ! .
    spike
  9. spike1947
    Feb 4, 2016
    39
    Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    Could it be the last item ( Transformer-less power supplies ) ! .
    spike
  10. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi spike ,
    I would say it is, perhaps if you PM'd a Moderator he/she will advise.
    E
