Hi everyone,
I'm not sure if most people know or not, but most of my postings are related to a single project that I have been working on. I wanted to see if someone can suggest a bypass capacitor to use for my circuit. The OUT1 and OUT2 go to a 0.8 Ohm 50mH inductance. It is being PWM switched at around 50KHz, but I may go up to 100KHz. The on-resistance of the FETs in the bridge are 0.15 Ohms nominal.
The sense resistors each go into their own differential low-pass filters with a cutoff of about 15KHz. I'm planning to sample the ADC at 30KHz. These differential amplifiers go directly into an instrumentation amplifier with selectable gain between 5 and 10. These should provide the actual current value in volts because I choose a 0.1 Ohm sense resistor. The gain of 5 is when the bridge is in slow-decay mode, which I would normally get twice the current shown. I'm using a simple logic circuit within the FPGA (not shown) to control this. I have supply filters on the opamps to reduce noise, I chose the cutoff to be around 10KHz, which is where the PSRR to frequency starts to really dip for both the instrumentation amp and the opamp. The TBD cap is a really small capacitance to eliminate the sense resistor spike when the h-bridge changes state.
Any red flags? Can someone make a suggestion? I'm going to check this over with a professor and it will be final lest anyone speaks from here.
Kindest regards,
Steve
Kindest regards,
Steve
