Scenix Microcontroller
Discussion in 'The Projects Forum' started by linkers, Jun 30, 2014.
  1. linkers
    Jun 30, 2014
    Hi, I have a project in which I would need to get information from a certan Microprocessor http://www.emesystems.com/pdfs/parts/SX48BD.pdf [SX52BD/PQ] (the datasheet provides a similar model). And I have a FRAM memory RIC FM24C16-P http://www.digchip.com/datasheets/parts/datasheet/000/FM24C16-P-pdf.php.
    The main question is - Would I be able to download the program located on the memory and after that alter it. The program is written in assembler, but it doesn't really make much difference.
    And if I would be able to download it, than how?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It depends on weather the security fuses have been programmed or not. If they have been programmed your only hope is to carefully slice open the package and using an electron microscope examine the memory cells one by one.
    See pp. 15-17 of the datasheet for information on the security fuses.
  3. davebee
    Oct 22, 2008
    539
    46
