Scattering parameters: Why V2=0 implies that the load is 50 ohms?
Discussion in 'Homework Help' started by lll, Jul 26, 2016.
  1. lll
    Mar 7, 2012
    21
    I'm refering to the equations for S11 in the attached picture. If V2+ is equal to 0, I would think that this is as if port 2 is short circuited, i.e. the load is 0 ohms, not 50 ohms. How could it be anything else? I've been flipping through the textbook for the last 5 hours trying to figure out what I'm missing, but no progress.
    DGElder likes this.
  2. lll
    Mar 7, 2012
    21
    For reference, here's page 2 of the example.
  3. DGElder
    Member
    Apr 3, 2016
    347
    87
    I think you are confusing V2+, which equals zero, with V2 which is not zero. V2+ signifies the voltage of the wave from outside the network going into port 2. Since there is no generator on port 2 and since there is no voltage reflected back from the load into port 2 - because it is a matched load, there is no wave going into port 2. Hence V2+ =0. The only signal at port 2 is that which was transmitted from port 1 and coming out of port 2, signified as V2-.
    So V2 = V2- = V1+ times s21: the transmission coefficient of port 1 to port2.
