Sawtooth Oscillator
Discussion in 'Homework Help' started by greggj, Dec 3, 2008.
  1. greggj
    Dec 3, 2008
    What component in a simple Sawtoo Ocillator develops the output cycle ?
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    A capacitor
  3. Ron H
    Apr 14, 2005
    7,050
    657
    It depends on the circuit. You can indeed change a capacitor and change the frequency, but there is always at least one other component that will also do it, e.g., a resistor.
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    A resistor, a capacitor, and a neon bulb make a nice relaxation oscillator
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    One method of producing a sawtooth waveform is to take a capacitor and charge it using a constant current source. This produces a linear increase in voltage across the capacitor since it is governed by the equation:
    \LARGE \frac{dv}{dt}=\frac{\LARGE i}{C}
    hgmjr
