Sawtooth from sine or square wave
Discussion in 'The Projects Forum' started by nenadilic84, Mar 1, 2010.
  1. nenadilic84
    Thread Starter Active Member
    Aug 7, 2009
    62
    I have recently built a DDS signal generator that has a sine and square wave output and can go up to 10MHz. Sine is adjustable form 0 to 2.5 Vp-p and square wave is actually a TTL/CMOS type square wave (5V). Now I'm looking for a simple circuit to have a sawtooth output (converting one of those two signals in sawtooth type signal). Can anyone suggest any design.
    Thanks in advance
    Regards,
    Nenad
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you just do it in the software?
  3. nenadilic84
    Aug 7, 2009
    62
  4. nenadilic84
    Aug 7, 2009
    62
    Thanks Alberto, I will try this to see if can go from 1Hz to 10MHz.
    EDIT: I can't find this diodes in my country. Do you have another suggestion??
    Thanks,
    Nenad
  5. Ron H
    Apr 14, 2005
    7,050
    657
    That won't work over a range of frequencies. The amplitude will be inversely proportional to frequency. AFAIK, the only way to convert a variable-frequency sine wave to a constant-amplitude triangle wave requires an automatic level control (ALC) loop. There would be a significant response time lag whenever the frequency is changed.
    What you really need is a system with a separate COS lookup table, or a chip which has a selectable path from the phase accumulator directly to the DAC.
  6. nenadilic84
    Aug 7, 2009
    62
    Where I live it is imposible to buy from them. Long story :)
    So you are saying that there is no easy way. I thought to use a square wave and integrate it, but I'm not sure that will work. Any suggestions on that.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could have the output charge a capacitor quickly, and then use a constant current circuit to discharge the capacitor. However, you will need to adjust the constant current circuit for each frequency.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    The integrator time constant would have to change whenever you change the frequency.
  9. redlight000
    Member
    Feb 26, 2010
    66
    Hi, there,
    re your request for a sawtooth device.. they not that difficult to do, & oddly enough not so easy as it first appears...
    I've not been a member on here for long, and came across loads of things relating to Square waves, sine, triangle, sawtooth... the help on here is outstanding.. but I learnt a awful lot by reading and reading the electronics over and over.. and if your heavily into complex wave forms and Generators. . then Go for this Book..
    110 WAVEFORM Generator Projects for the Home Constructor.. by R.M.Marston...
    The book is really outstanding.. he covers all the stuff that Ive read relating to signals generator.. specialised ones as well for instance he covers the Chip The XR-2206, IC.. and is available in the UK.. well thats where I got it from ..mind you I did not use that much..!!! never the less go for this book he really know sound waves equations inside out...
    Yes it will be hard to grasp at first.. but well worth it.. Ive built from this & then modified the Generator circuits to suit my needs hmm takes time but one gets there..
    Good luck..
    PS: The book is by Newnes Technical Books..
    so Im afraid you will proberly have to go on Ebay.. to look for it.. it was published in 1978!! many Moons ago lol
    cheers all hope this helps
  10. rogs
    Aug 28, 2009
    279
    37
    In your original post you talk about generating a sawtooth wvaform. Since then the thread has been about generating a triangle wave.
    Not the same thing. A triangle wave is a modified form of square wave, and contains only odd harmonics. A sawtooth contains all harmonics.
    See here:
    http://www.csounds.com/ezine/spectra/ about half way down the page for the harmonic difference between the two.
    If you're looking to generate a sawtooth, then you're not going to derive that from either a sine wave (no harmonics) or a square wave (odd harmonics only).
