Saturating a Transistor for a Single LED
Discussion in 'General Electronics Chat' started by ELECTRONERD, Jul 29, 2009.
  1. ELECTRONERD
    Thread Starter Senior Member
    May 26, 2009
    1,146
    16
    Hey,
    I am in dire need of help, I am so frustrated! Here is what I need: I am trying to saturate a 2N3904 transistor so that it will turn a single LED on and off. It is similar to the following circuit:
    Except that I only want one LED to turn on and off. I realize that while one transistor is off, the other is on. Thus, it keeps the LED's alternating as well. The 470Ω resistors determine the current to the LED and the 100K sets the saturation current. I want to be able to calculate what resistors I need and how long I want the LED to be on and off. I DO NOT want to use a 555 timer but ONLY transistors; I want to be able to do this myself.
    If you look at Figure 2 at the last page of the 2N3904 specs (http://www.fairchildsemi.com/ds/2N/2N3904.pdf), it shows the storage and fall time of the transistor, so I know that a single LED can accomplish this. I also see a 4pF cap between the collector and emitter I suppose this determines the time that it is on and off so I could use a higher value cap to make the duration longer. I'm not sure though, so PLEASE help me!
    Thanks in advance!
    SPQR likes this.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What you have is a multivibrator. If you want only one LED to flash, remove the other one (jump it out). You want to learn more - http://www.technologystudent.com/elec1/dual1.htm
    The way to use fewer devices is to get a unijunction transistor like a 2N2646 and make a relaxation oscillator.
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    Sure, but, couldn't a single transistor do the job? I'm sure it can!
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    If the LEDs are 2.0V red ones then their current is (9V - 2V)/470 ohms= 14.9mA.
    The datasheet for the 2N3904 transistor shows it saturating well with a base current that is 1/10th the collector current.
    Then the base current should be 1.49mA.
    The base resistor should be (9V - 0.7V)/1.49mA= 5571 ohms. Use 5.6k. The 100k is far too high.
  5. Jony130
    Feb 17, 2009
    3,991
    1,116
    But if use Rb=10KΩ transistor will be in saturation or not ?
    PS.
    Yes, whit the negistor
    http://www.cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    A UJT is also a transistor of a sort, a specialized unit if you will. As beenthere suggested, it would do the job with the transistor, a capacitor, one or two resistors, and a LED.
    I don't think you'll be able to do it with a BJT though.
  7. ELECTRONERD
    May 26, 2009
    1,146
    16
    But will 5.6k saturate the transistor? I thought I would use a resistor at the base to saturate the transistor and the resistor at the collector will determine the current for the LED. I could have a 10mA LED by the way, instead of using some 20mA ones that I have.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    A 100k base resistor in that multivibrator circuit might saturate a few 2N3904 transistors if you have a bucket full of them.
    10k will saturate most 2N3904 transistors in a bucket full.
    5.6k will saturate all transistors if they are made by a well known manufacturer.
    Use 5.6k if you want every circuit you make to work properly.
    Most ordinary LEDs have a maximum current rating of 30mA. They are tested and spec'd with a current of 20mA. You can operate them at 10mA or 5mA if you want.
  9. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    According to my NRI course manuals,
    IB > (IC / Beta. min.)
    They go on to say that to ensure saturation, with modern , (general purpose transistors),
    IB > (IC / 10) is a good starting point.
  10. Jony130
    Feb 17, 2009
    3,991
    1,116
    Well, to be more precise, in this multivibrator circuit the 2N3904 will be in saturation, because the base current that saturate the 2N3904 will be coming from the Vcc-->LED-->470--->10uF (10 uF -capacitor charging current).
    And you have to remember that statistically mostly 2N3904 will have Hfe much higher then minimum from datasheet.
    Most 2N3904 will have Hfe that is show in a graph "typical Current Gain".
    PS. I know I pick on
  11. daroc26
    Apr 4, 2009
    30
    Hi Electronerd,
    I'm working on the same circuit, however my goal is to make both LED's flash.
    Can anyone tell me how to make this circuit work with +3v? How can I calculate the resistors I would need if using +3v instead of +9v?
    All week I've been struggling with changing the resistor values, but no luck.
    Thank you!
  12. Jony130
    Feb 17, 2009
    3,991
    1,116
    Try this circuit
  13. daroc26
    Apr 4, 2009
    30
    Brilliant, just what I needed :D
    Can I ask where you found that?
    Thank you!
  14. ELECTRONERD
    May 26, 2009
    1,146
    16
    Well, I suppose I'll have to use two transistors to make this work. One to turn the LED on and the other to turn it off. I saw that one circuit without the base connected to anything, but how does that work? If anyone has any more saturation calculations I'd be glad to know.
  15. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, but if the base resistor is too high to keep the transistor in saturation after the cap is charged, then the timing will be a function of beta, and the LED current will be reduced, and also a function of beta - not generally desirable.
