The thermal characteristics may be different but I don't think there's any significant difference in the electrical characteristics.Aren't the characteristics different for the TO-18 can the (a) version the OP is using?
Days after a question came to my mind;Hello,
Here I found a datasheet with a saturation curve:
On the corner there is stated they used Ic = 10 X Ib.
Bertus
Depends upon the collector current...............................
So, I would conclude that this transistor is saturated at any value of Ib in the range of 1-100 mA. Is this correct ?
That's the point confusing me. Ic can be selected as 1 mA and then by choosing the Ib 1/10th of the collector current, which is 0.1mA, we would guarantee the saturation. And if I try to draw more than 1 mA current with any load attached to collector, I simply wouldn't.Depends upon the collector current.
It's reliably saturated when the base current is at least 1/10th of the collector current.
Not sure what you mean by "would always be saturated"?That's the point confusing me. Ic can be selected as 1 mA and then by choosing the Ib 1/10th of the collector current, which is 0.1mA, we would guarantee the saturation. And if I try to draw more than 1 mA current with any load attached to collector, I simply wouldn't.
That's what I think of. So, BJT would always be saturated if there is a current on the base, but the current we can draw would be dependent on Ib.
Am I correct ?
Let's turn this around. Suppose we select Ib to be a fixed 0.1mA, and then force a range of currents between 0.1mA up to about 20mA into the collector of a typical 2N2222. Here is a simulated plot of Vce as a function of the collector current, plotted log vs log. Note that for Ic = 1mA, the Vce is low. Even if we grabbed a '2222 with the lowest β, it would still work as a switch at Ib=0.1mA at an Ic=1mA....Ic can be selected as 1 mA and then by choosing the Ib 1/10th of the collector current, which is 0.1mA, we would guarantee the saturation. ...
Okay now it's clear, I thought that Ic is limited by the selected Ib, but now it's obvious that I can draw more than selected Ic and that's the thing leads to unsaturated state.Not sure what you mean by "would always be saturated"?
To insure saturation you need to keep the base current at least 1/10th of the collector current. You can draw more collector current then that for a given base current but, at some point, depending upon the gain of the particular transistor you have, it will come out of saturation and the collector-emitter voltage will start to increase.
The point of saturation is not a hard point. The transistor gradually goes from being saturated to unsaturated as the collector current is increased for a given base current.
Glad to see this in writing.end of life degradation.
