we have a splice in our coax cable between the satellite modem and the dish. this connection has ended up being the culprit in about 80% of the problems we have had. I have tried reversing it, covering with tape, cleaning the center conductor with fine sand paper. none of this seems to be helping. seems like something touches one of the cables or splice and it looses connection. figured just got loose or dog bumped it or got bumped while we were outside, today have issue go out and find a garder snake by it.
I can't think of anything else to try to fix this issue, special splicer too has pair of rubber gaskets that cover connections since outside. I'd replace it with just another coax splice, but not sure handle type of signal and I'd have to tape it up to seal it.
talking to one of my friends that's an electrician said those splices can be problems at frequencies like that.
I'm getting really frustrated always having to go out and fix that.
any suggestions to try to use existing connection and making work better or some sort of permanent way to just join the cables with no connectors? my guess is always have issue as long as splice there meaning have to replace the hole cable to get around that.
