Sanyo Z5 fan replacement
Discussion in 'General Electronics Chat' started by ronkvogel, Oct 14, 2010.
  1. ronkvogel
    Oct 14, 2010
    Hi, i just bought an used Sanyo Z5 today for a low price with an extra bulb too. When demonstrated, the rattling noise appeared. rrrrorrr. . I searched for this projector beacause it should operate very quiet; i like that!
    I found this threat by typing "2810KL-04W-B39" into google; one of the axial fans.
    At first i am going to test the 2 axial fans and see if they are producing too much noise. They are easy too reach and with a bit of luck they are the guilty one(s) I will test them on the 12 volt line in my computer which already is controlled manually.
    My feeling says that the 3 lines just do this: red/black applying an amount of voltage to let em work and the yellow line just says: yea this one its ok this one is still turning around at x rpm; so then a processor can vary the rpm.
    i must be able to replace these fans (if they are guilty of noise) with 70 mm quiet ones from a Personal computer do it your self shop; the best ones around offcourse.
    Greetz from Holland
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  3. ronkvogel
    Oct 14, 2010
    this one can be closed. Fans are available at service centres.
