Sanity check please: current limiter using LED
Discussion in 'The Projects Forum' started by Robartes, Oct 26, 2014.
  1. Robartes
    Oct 1, 2014
    57
    13
    as I'm just starting out in electronics and I had an old CPU power supply available, I thought to create everyone's favourite first project: an adjustable lab supply. As part of the lab supply, I want to build in a current limiter circuit. I came up with the below:
    I've tested this on a breadboard and it seems to work - with the value of R1 as stated (2.2 ohm, actually 3*6.8 ohm 1/4W in parallel) the current is limited to around 550mA when I short circuit the load. Of course, the transistor and the resistors get hot (although the power through them is still within spec for both) when they need to pass this current.
    I know the classic version of this circuit uses two diodes instead of the single LED, but when I use the LED I get a nice indicator of the circuit pulling too much current.
    Now to my question - does anyone see any glaring mistakes or caveats in this circuit? Thanks!
  2. ScottWang
    Aug 23, 2012
    4,936
    777
    How about the Vcc, Load, Led type V/I?
  3. Robartes
    Oct 1, 2014
    57
    13
    Vcc will be +12V maximum, the load can be anything (basically what's connected to the lab supply, so abstract it as say a 10K resistor). For the LED I have no detailed V/I curves -- it's a standard (for what that's worth) red LED which in my calculations I assumed drops 1.8V.
    Edited to add: to measure is to know, as we say (trust me, it sounds snappier than that in my native language :) ) I measured the voltage drop across the LED when the transistor on, ie when the load is a short circuit - the LED drops exactly 2V in that condition, with Vcc being +12V.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    No obvious mistake, and you're clearly aware of the power handling constraints. LEDs are commonly used as crude voltage references.
  5. ScottWang
    Aug 23, 2012
    4,936
    777
    There was something wrong with current what I calculated in the attached circuit .
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    When Q1 collector/emitter current is ~500mA the Vbe won't be as low as 0.7V. It will probably be nearer 0.9V (depending on the transistor).
  7. ScottWang
    Aug 23, 2012
    4,936
    777
    Yes, Vbe even could be 1.1V, but the Ib still has a long distance error.
  8. #12
    Nov 30, 2010
    16,705
    7,358
    It's a perfectly valid concept that will work as long as you don't go around exceeding maximum voltages or power limits.
    Devil in the details and all that...
  9. crutschow
    Mar 14, 2008
    13,526
    3,393
    How did you get such a high base current? The typical beta of that transistor, which is operating in the linear mode, should be in the neighborhood of 100, giving a few mA of base current.
    Johann likes this.
  10. ScottWang
    Aug 23, 2012
    4,936
    777
    Only the Ib=Ie-Ic.
  11. Johann
    Nov 27, 2006
    190
    30
    And Ir2=Ib+Iz
