Samsung Plasma PS51E450
Discussion in 'General Electronics Chat' started by R!f@@, Dec 6, 2014.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,787
    771
    I am Primarily asking Tom66 for help but others are most welcome
    I read at badcaps forum about this model.
    I do not wanna register every where.
    Tom66 answered the post there.
    It seems he has more experience in Plasma's than me.
    I am troubled with the model in Post header.
    I read thru the badcaps forum hence here are my findings.
    Checked the buffer for shorts and did not find any.
    The screen flashed snow as far as I can see at power up but it lights one third of the screen. Screen bottom flashes.
    Vs,Vsc.Va and Ve can be measured for a second or so. Reading can be taken during the flash or power on.
    After that the panel supply decays. So need to reboot to take measurements. DC voltages can be adjusted to the value stated on Panel.
    I believe supply is OK.
    The TV can be switched to standby by remote and can be turned on again.
    At turn on the snow is not completely white. But rather it has colored lines but snow is there. I need to capture a video of it I think.
    Cannot find any shorted components on ZY and said above buffer shorts are not there.
    I am lost as of now
    By the way the LED on T-CON is flashing. On for 5 seconds and off for 2 seconds.
    I cam here the SMPS or supply area switch on noise around Vcs when the display comes on and goes off with the screen
  2. sheldons
    Oct 26, 2011
    616
    101
    You may have a missing supply or need to replace z-sus or y-sus and the associated drivers or it could be a software issue. ....if it is Compaire would be handy for fault finding. ....have you disconnected the z and y sus boards etc then checked the power supply on its own? May even be ssb related
    R!f@@ likes this.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    I will do some research later to help out ...
    Sorry almost forgot.. When I work on repairing tv's , most of the time I look for repair kits for that model of tv and see whats a common problem and start there and most of the time that helps out alot...
    R!f@@ likes this.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    I replaced the PSU and Mobo....before..same issue.
    I think I can rule out mobo and PSU. I do not have the SUS PCB's to check.
  5. R!f@@
    Apr 2, 2009
    8,787
    771
    Funny....The video on how to check Buffer did not help..!
    Replacing the buffer did the Job.
  6. Zygm
    Jan 8, 2015
  7. R!f@@
    Apr 2, 2009
    8,787
    771
    And ???
