Samsung Galaxy Tab 4 micro usb charging port is damaged
Discussion in 'General Electronics Chat' started by satcom, Jul 23, 2015.
  1. satcom
    Apr 1, 2015
    24
    Samsung SM-T700 Galaxy Tab S - Micro usb charging port seems is damaged. Is this micro usb charging port a separate component of PCB, can it be easily replaced?
  2. nsaspook
    Aug 27, 2009
    3,013
    2,362
    Here are a few pictures of Samsung Galaxy devices: Teardown
    Good luck.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    I assume it's no longer under warranty... Pop it open and check for yourself.
    Here's a teardown of a 10.1; maybe you'll be able to make out the USB connector. I have 4 of these tablets, but haven't needed to open any of them...
    EDIT: correction, I have the Tab 4 8.0; that explains why I couldn't find the USB connector where I expected it to be...
  4. satcom
    Apr 1, 2015
    24
    The model is Samsung Galaxy Tab S 8.4" SM-T700 (I mistyped model in topic subject)
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    If you have to ask you can't :)
    Have you desoldered anything before? SMT?
    Are you very good at soldering very small components?
    Do you have a soldering iron or hot air gun?
    If you answered yes to all then go for it.. If not.. Good luck
  6. satcom
    Apr 1, 2015
    24
    Probably not very good at soldered small components, I was going to bring it to repair service. I'm not sure, does this particular model have this part soldered or its like small module mounted as disconnectable crimp style connector? In the last case, its more easily to do. If I'm not mistaken, this part is module, what I find:
    EAN: 0634972700875
    MPN: GH96-07263A
  7. dl324
    Mar 30, 2015
    3,378
    651
    The first thing you should do is open up the case and check the solder joints on the USB connector. If you don't have the appropriate tool, you could try a guitar pick.
    I once had a DVD drive stop working so I started salvaging parts from it. While I was doing that, I found a ribbon cable that wasn't soldered very well and suspect that was what caused it to stop working; but not before I had rendered it useless.
  8. nsaspook
    Aug 27, 2009
    3,013
    2,362
    I hate it when that happens! A general recommendation for future devices is to check for wireless charging or aux power port charging. That micro usb port was not designed for the abuse it gets.
    Qi on the Nexus series devices is mighty cool.
