You must send it back to the shop where you bought it as soon as possible. If you don't know much about these kind of displays it will result bad. You may lose your guarantee if you try to repair it. And worst scenario if you can't repair it, you will loose more money to take somoene to repair it.
Just last night I got lucky (thanks to the people at AAC). I looked inside a big screen TV with synchronization problems and saw a matched pair of swollen capacitors.
They will arrive tomorrow and I'll install them. If I'm lucky, that will cure the problem.
Samsung are notorious for their underspec capasitors mounted all too close to heat disipating radiators all over the TVs.
Buy better caps and replace them all. (Should be around 10 pcs)
Also try to mount them a bit away from the radiators.
Better with some of the leads on top of the pcd and the capasitors body away from the radiators. Insulate exposed part of capasitor wiring for safety.
Good luck.
