Sample & Hold circuit
Discussion in 'General Electronics Chat' started by perzade, Jun 24, 2012.
  1. perzade
    Jan 30, 2011
    I m sending temperature readings to uC thru ADC0804 & sensor is LM35. Do I require a S/H circuit as I hav directly interfaced LM35 to ADC or does it have internal S/H circuit??Plz reply asap
  2. Ron H
    Apr 14, 2005
    7,050
    657
    LM35 does not have an internal S&H. You shouldn't need one.
    perzade likes this.
  3. crutschow
    Mar 14, 2008
    13,492
    3,372
    S/H circuits are needed if the measured voltage is rapidly changing and you need to capture the voltage at a particular point in time so the A/D has a stable voltage to convert. For a relatively steady voltage, such as the output of the LM35, a S/H is not needed as Ron H noted. But many A/Ds already have a built-in S/H (stated in the data sheet) so, even if you did need a S/H, you wouldn't have to add an external one.
    perzade likes this.
