Sample and hold circuit
Discussion in 'The Projects Forum' started by bobmcm, Jan 11, 2007.
  1. bobmcm
    Jan 11, 2007
    I need a circuit to hold the last 4-20 ma dc signal until it receives a new signal.
    This is for a pressure tester.
    The pressure is increased untill the test subject ruptures, and the
    pressure transducer signal signal drops to 4 ma, I want to hold the
    signal value at the point of rupture until it is manualy reset or receives a new signal.
    Any help would be greatly appreciated.
    Thank you in advance.
    bobmcm
  2. n9352527
    Oct 14, 2005
    1,198
    What you probably need is a peak detector instead of just a S&H. Usual implementation is a precision rectifier followed by an opamp. You could also go with an IC that does all these, like PKD01 from Analog Device.
    You have to convert the 4-20mA signal to voltage first.
  3. ronv
    Nov 12, 2008
    3,392
    1,449
    Hi Bob,
    If you want to send me an e-mail address I will send you a circuit. I'm guessing you can measure the result with a voltmeter and that the build up of pressure happens fairly slowly.
    Is powerpoint okay?
    Ronv@wbhsi.net
  4. ronv
    Nov 12, 2008
    3,392
    1,449
    Hi Bob,
    If you want to send me an e-mail address I can send you a circuit. I assume you can measure the output with a voltmeter and that the pressure builds up fairly slowly.
    I'd paste it here but I don't know how.
    Is Powerpoint okay?
    Ronv@wbhsi.net
