Unfortunately, I can't get access to one of these for the our electronics store.Instead of comparators just use an LM3914 bar LED display driver.
You forgot to put a Track switch in series with R1. And why does the output go up rapidly in the beginning of the integration time?Here is a tina simulation of the circuit ....
VG1 is offset by 2.4V is a 1V pink noise audio file.
The free version of TINA is TINA-TI.
You have chosen a poor op amp for this application. It has high bias current and high offset voltage.I've been trying to prototype and debug the attached circuit for almost a week now and almost have it working. At the moment only the integrator is not working properly and the output voltage dips relatively quickly (a bit too quick) when the integrator does work. I haven't been able to find out why exactly why, but it appears that all the BJT's are switching and the 'track' and 'rst' signals are being timed properly. Basically, the integrator is not integrating/ignoring the sensor output. When I use the sensor the resting voltage out (from the sensor node) is 0.65v, but it rises to ~2.7v while the track signal is high and then returns to 0.65v. If I replace the sensor with a voltage supply there is no rise in voltage. The output of the integrator goes to 1.8v (regardless of input voltage) when using a voltage supply, but with the sensor it only reaches ~1.3v. Any thoughts on what might be going on, and how to buffer the output so it 'holds' the voltage longer?
The MC33202 input bias current is 200nA max.It will hold that voltage with very little change for a long time, assuming you choose a zero bias current (CMOS) input op amp, and a low-leakage, low dielectric absorption capacitor (polypropylene or polystyrene).
I suppose I should have qualified "low". I would shoot for <250uV. The MC33202 has 8mV maximum input offset voltage. I'm guessing you chose it for rail-to-rail output and the through-hole package. I can pretty much guarantee you that a rail-to-rail CMOS op amp with low offset voltage will only be available in a SMD package.You should choose an op amp with low input offset voltage.
If you need help developing Track and Reset signals for the 4066 switches, let us know, and post a timing diagram.You can use a 74HC or 74HCT4066 for the switches (4 per package).
I can't get those parts for the project unfortunately - our store doesn't stock them. I'll try your suggestion regrading the op-amp. Is the attached picture right (only using 1 op-amp)? I might also be able to get a solid state relay, would that be suitable failing the op-amp idea?You can use a 74HC or 74HCT4066 for the switches (4 per package).
Again, it's down to being limited by the specifications we were given for the project. I can't do anything about it except design around the problem. For any other project I would order parts, but for this project we are forced to only retrieve parts from the one local store.Why can't you use mail order?
by Duane Benson
by Jerry Twomey
by Duane Benson
