Hello to all,
I have to design a S-K LP filter circuit using two LM555 timers, two LM741, and a 74HCT4016(analog/digital switch). I'm suppose to take the outputs of the 555's which will be square waves and change them into sine waves from the outputs of the two op-amps. One output will be at 1.2kHz and the other at 2.4kHz. Can someone steer me into the right direction to get started. And will this be a 4 pole S-K LP filter circuit?
Thanks,
Jason
Thanks,
Jason
