sallen key low pass filter
Discussion in 'The Projects Forum' started by Ainy shaikh, Apr 24, 2012.
  1. Ainy shaikh
    Apr 20, 2012
    whats the effect feed back resistor in sallen key low pass filter.....
  2. crutschow
    Mar 14, 2008
    13,475
    3,361
    It creates the second-order function that such a filter requires.
  3. mlog
    Member
    Feb 11, 2012
    276
    36
    Isn't the feedback resistor in the high-pass configuration?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You can have a feedback resistor in the non-unity gain configuration for the low pass case. In that case the feedback resistor forms part of a two resistor non-inverting gain configuration.
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    My response was incorrect. :p t_n_k is correct. In the normal Sallen Key filter low-pass filter, the feedback resistor (if used) is just to determine the gain of the op amp.
