Hi everyone.
Im new here so be gentle.
Also new in playing with circuits and for my first project I would like to recreate something similar to this:
http://www.sailsafely.com/photo_and_guide.htm
Im not looking to steal his design, just have an interest in learning circuits and figured I could create something usefull as I do.
Its a simple device that short handed sailors use so they dont hit anyone else (you need to sleep sometime).
You set a time, and it counts down from that. Everytime you look around you reset the unit and it starts again. Once the time expires a quiet beep sounds for 30 seconds to remind you to look around. If you dont hit reset once the beeping cycle ends a loud buzzer or horn is sounded until reset is hit.
The easist way I can see to create it is as follows:
I havent purchased anything yet so a nudge in the right direction to get me started would be helpfull.
Gary
- Two timers that both start when power is on. The first one lasts the desired time interval (in various periods from 5 to 20 minutes). The second one lasts the same interval plus around 30 seconds.
- When Timer 1 ends a quiteish beep (similar to a watch beep) is emitted until reset button is hit
- When Timer 2 ends a loud horn or buzzer sounds until reset button is hit.
- When reset button is hit the process starts all over by resetting both timers.
Gary
