I have read up on some other threads and done research on water level sensors. I have a decent idea of what I am going to do, but before I blow something up I wanted to check here. I know I'll have something wrong.
I have a reservoir with a Reverse osmosis pumping water into it for my fish tank. I have a float valve that controls the water level, but I've been told that these go bad so, as a backup, I am installing a DIY float sensor that triggers a solenoid.
I have these parts:
I wanted to integrate a buzzer as well, but I'm thinking v1.00 should be simple. Am I missing any components before I start this?
Any advice/comments would be appreciated. Thanks
I have these parts:
- Generic float switch (http://www.bulkreefsupply.com/standard-generic-float-switch.html)
- Solenoid valve / 24VAC -- closes the water line -- (http://www.freshwatersystems.com/p-...ff-solenoid-valve-with-qc-fittings-24vac.aspx)
- 24V AC power supply (http://www.radioshack.com/product/index.jsp?productId=3832489)
- OMRON Relay, 8 Pins, Dpdt (http://www.grainger.com/Grainger/OMRON-Square-Base-General-Purpose-Relay-2W930)
- OMRON Relay Socket (http://www.grainger.com/Grainger/OMRON-Relay-Socket-For-Double-Pole-Double-4DG59?BaseItem=2W930)
- Project enclosure (http://www.radioshack.com/product/index.jsp?productId=2062282)
