Does anyone have the ability to put together an electrical model explaining the theory behind identifying a safe minimum electrical resistance for grounded flooring used around energized equipment?
The model would need to explain what would happen if a person touched 120 or 220 at the same time as they were making electrical contact with the conductive flooring.
I am interested in putting a chart together that would identify the range of electrical currents a human body could experience based on decreasing resistance levels in the unlikely event of contact with AC voltages while touching grounded flooring. Many grounding standards like ATIS 0600321, FAA STD 019e and Motorola R56 recommend a minimum resistance to ground of 1 million ohms for static control flooring.
The flooring is used to prevent static electricity discharges in equipment rooms.
