Safety in simple circuits
Discussion in 'General Electronics Chat' started by Shmurk, Mar 3, 2009.
  1. Shmurk
    Aug 13, 2007
    24
    I'm currently reading the chapter 10.3 of the book, the one about the Mesh current method to analyze DC circuits with a few resistors and multiple voltage sources.
    Everything looks good on paper but I want to try it in real life, and I'm wondering if these simple circuits are "safe." I'd like to test my calculated results with a multimeter (it would last just a few minutes) and I'd like to know if there is any chance that my resistors can overheat or explode (or empty my fridge without my permission ;) ), or if my batteries can die really faster because of the "uselessness" of the circuit.
    Yes, it's a rather stupid question but, well, I wonder...
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Good chance to use ohms law to compute expected current and power. That said, use a current limited power supply ( a small 9 volt battery for example ) and I doubt you could blow anything except the current range on your multimeter. ( do not use the current function, measure the voltage across a resistor and ohms law to get the current )
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's not a stupid question at all!
    The low resistances specified in those circuits would result in high currents, and large power dissipation in the resistors. Real batteries would rapidly become discharged. The resistors for some of the circuits would need to have a high Wattage rating; for example in the first schematic, R1 should be rated for 200 Watts! :eek:
    Power(Watts) = I^2 R (Current Squared times Resistance), in this case 5^2*4=100 Watts; you always double the wattage requirement for reliability and lower heat.
    Rather than build the actual circuits, I suggest you use a PSpice simulator.
    Linear Technology's LTSpice is good, and free.
    You can download it here:
    http://www.linear.com/designtools/software/
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    I have always calculated the max current and max power properly so i have never had anything blow up.
  5. mik3
    Feb 4, 2008
    4,846
    63
    If you use voltages below 50V then you will be safe.
    As for the resistors if they are not of the proper wattage they will overheat and burn.
  6. Shmurk
    Aug 13, 2007
    24
    Thank you for all the answers, this really gives me the incentive to keep on studying electronics!
    Here is what I'll do:
    • use one 9V battery, one 1.5V battery, and a few 1/4W resistors
    • compute expected current and power by hand
    • check my results with Spice
    • build the actual circuit and check with a multimeter
    Thanks again!
  7. leftyretro
    Nov 25, 2008
    394
    Good plan. Keep in mind that calculated results and measured results will differ somewhat as components have manufacturing value tolerances differing from their marked value.
    Lefty
  8. Shmurk
    Aug 13, 2007
    24
    I'll have to explain why I insist on building the circuit with real components:
    I'm a C/C++ programmer, and when I began, I read programming books for 6 months without writing real programs. At the end of these 6 months, I knew... nothing! It was a disaster. Programming was harder than I thought, and I really learned and understood what was in the books when I wrote my own programs. That's why I want to do it for real right now, I don't want to wait till I've read the book to the end.
    I've already learned a lot about electronics by building simple circuits and comparing my breadboard circuit with what's written on paper. It seems to work the same way as computer programming.
    Thanks again for all your support :)
  9. leftyretro
    Nov 25, 2008
    394
    I agree that real world experience cannot be accomplished solely on simulations or book reading. Both have there place under the sun these days. While I'm pretty old school (and just old also :p) So simulators don't work well for me, but I certainly appreciate the power these tools have with the ever increasing complexities of designs these days.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    The AAC book has a good volume of hand on type experiments. Volume VI, on the top of the main forum page.
  11. russ_hensel
    Jan 11, 2009
    820
    47
    No simulator can give you the thrill of putting a heavy wrench across a car battery and watching it glow. Do not try it at home.
