Please help me in this project:
+ Using a rotary switch potentiometer to adjust output voltage.
+ After resuming from power failure, the output voltage is auto down to 0V although the pot is still remained.
+ In order to activate the output voltage again, the pot must be turn all the way back till the switch is off and then turns it on again.
I very appreciate your kindly help.
