Safety Capacitor Question
Discussion in 'The Projects Forum' started by tcawley29, Apr 2, 2013.
  1. tcawley29
    Jan 23, 2013
    47
    Okay so I have a treadmill which the motor is not working on. I think it may be a problem with the safety capacitor. Anyways, I think the safety capacitor is the problem because there is 235 volts ac entering the circuit board. Next on the negative lead is the safety capactior. I think this is it: http://www.ebay.ie/itm/10pcs-Safety...ultDomain_0&hash=item5644329153#ht_762wt_1037
    The next components up from the safety capacitor is four diodes for bridge rectification. Here I am only getting 3.7 volts dc.
    Would this mean the safety capacitor is the problem. All of the diodes have been tested and deemed working.
    Does this mean the safety capacitor is the problem.
    Thomas
  2. DickCappels
    Aug 21, 2008
    2,768
    669
    This answer is based on an incomplete picture of your circuit. If you can post a schematic, even if a photographed pencil sketch, it will help.
    Probably not. The safety capacitor is in shunt with the input voltage and it is designed to clear any shorts it might develop.
    Can you post a schematic?
  3. tcawley29
    Jan 23, 2013
    47
    Here is the schematic. Its driving me nuts as to why I cannot get this sorted.
  4. tcawley29
    Jan 23, 2013
    47
    Anyone at all?
  5. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Check TVS2, or the relay with your meter to see where the vpltage stops.
