Safe AC for exercises.
Discussion in 'General Electronics Chat' started by hp1729, Feb 14, 2016.
  1. hp1729
    Nov 23, 2015
    2,105
    235
    Some exercises just can't be done without AC. Since my breadboards are battery powered I need a way to supply AC that is safe and available. The attached circuit was what I came up with. 60 Hz, variable voltage, modest output current.
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Nice, but I'm curious as to what exercises you'd be doing, given that the battery supply and push-pull output stage will obviously limit the current you can draw?
  3. DickCappels
    Aug 21, 2008
    2,780
    675
    Looks like a good circuit for modest amplitudes and power levels. By the way,
    Incidentally, you can do many AC experiments using a capacitively couple square wave too, and you might find that easier to build..
  4. hp1729
    Nov 23, 2015
    2,105
    235
    Diode, rectifier, basic power supply design, triacs. Peak vs RMS AC voltages, amplifiers, transformers ... Yes it is intentionally low and safe for those in first year electronics.
  5. hp1729
    Nov 23, 2015
    2,105
    235
    Yes, just for early basic classes. Sometimes you just gotta have a sine wave to talk about sine waves.
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Ah, in that case I suggest you need some sort of current-limiting arrangement to prevent your AC supply frying when the students short-circuit something (which they will :)).
    Sinus23 likes this.
  7. hp1729
    Nov 23, 2015
    2,105
    235
    :) good suggestion. Depending on the op amp used, parts are about $1. I keep it build up on a small breadboard like most of my "doodad" circuits. Voltage regulators, adjustable voltage references, and such. All possible to be built in under $1. The dual op amp used is a TL062 but most any dual op amp designed for + and - 15 V will do. Or you could even use two LM741s. What ever you have on hand.
    Buy prime parts? Only by exception. For the most part I buy "grab bag" parts, in bulk or the cheapest possible. Seldom I will buy prime stuff. I gotta have a good reason.
  8. hp1729
    Nov 23, 2015
    2,105
    235
    Something like this?
    It makes the cheap, disposable circuit more complicated. If I were selling a marketable product. maybe. There are single chip solutions on the market but I designed this for parts on hand.
    This brings down the output voltage a bit, too.
  9. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Unless I am missing something, what is wrong to use one of the older mains transformer Wall Warts, the DC portion can be removed if necessary.
    Max.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    You can buy AC only wall warts.
  11. hp1729
    Nov 23, 2015
    2,105
    235
    Very true, but battery powered was a requirement.
  12. hp1729
    Nov 23, 2015
    2,105
    235
    Very true. I suggest using what you have available. Battery powered was one requirement.
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Do you want 60 Hz? A power audio amp (DIY) will meet most of these requirements.
    I found a circuit in the ebook that is similar to yours, but will have less crossover distortion. Give me a bit and I will post it.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    BTW, I have a similar project in work, different emphasis. A AC signal from a single power supply.
    I have some peanut bulbs, 1.5V at 20ma.
    Be back with the other circuit.
  15. hp1729
    Nov 23, 2015
    2,105
    235
    Excellent idea! Just not anything I have on hand.
  16. hp1729
    Nov 23, 2015
    2,105
    235
    Also excellent. 440 Hz? A above middle C?
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    A = 440 Hz
    What most tuners use.
    This is the amp, I designed it to dovetail with the Wien Bridge Oscillator. My thought is you can take whatever works for you out of the design.
    It should be a really clean AC signal, keep the battery isolated from the rest. If the input signal is near the battery voltage the P-P will be nearly twice the battery voltage.
  18. hp1729
    Nov 23, 2015
    2,105
    235
    Super!
  19. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just merged my schematics. I'll be posting this on a separate thread sometime in the future, after I test it.
  20. hp1729
    Nov 23, 2015
    2,105
    235
    Using my previous oscillator and the suggested output stages the transistors in the Q1 and Q2 positions kept self destructing. I couldn't find what I did wrong after many attempts I modified the outputs to something I knew. Yes the output was larger, as expected.
    The light bulb in the Wein oscillator ... is it the inductance of it that matters or the changing resistance, or what?
