SA- NE555 timer anomoly
Discussion in 'The Projects Forum' started by lost_bro, Aug 11, 2014.
  1. lost_bro
    Mar 17, 2009
    9
    Good day all!
    I have recently completed an automatic water pump control circuit for a solar powered water pump.
    It will sense water levels (with remote sensor, copper wire) and run the pump according to the water /sensor levels.
    Also it has a -run dry- protection feature that will shut off the pump if the -run dry- sensor loses contact with the water.
    OK, I designed and built the circuit using some -old- SA555 T.I. chips that I had on my bench from maybe 5 or 7 years ago. And the circuit runs as expected.
    Now, I ordered from China some 'T.I.' NE555 chips and to my surprise the timer delay function for the -run dry- feature no longer works as it does with my 'old' T.I. chips from many years ago!!!
    Basically, the observed problem involves Q1 and D1 circled in RED. Q1 should not be conducting when the start up timers is active and counting.... (when the start up delay timers expires then Q1 begins to conduct.).
    With the new Chinese NE555 chips , Q1 conducts ALWAYS except for when I remove the Ground to D1. Then the circuits runs normally as with the 'old' T.I. SA chips. So, the path to ground to bias Q1 is thru D1 with the Chinese chips. I don't understand because if that is the case then why does Q1 NOT bias thru the D1 ground when using the old T.I. SA chips?
    So, I put the old 'T.I.' SA555 chip back in the circuit and all functions are a GO.
    So, my question is: Can there really be that big of a difference in these common 555 chips to make my circuit STOP functioning? :confused:
    Sorry about the hand drawn circuit. Didn't have time to LTspice it.
    I would appreciate any and all commentaries, probably I am overlooking something very obvious here.....;)
    Thanks in advance, just let me know if anyone requires more info.
    lost_bro
  2. GopherT
    Nov 23, 2012
    6,339
    4,094
    You either forgot to 'burp' your Tupperware or the chips are bad/counterfeit/designed differently than your old chips.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Your schematic shows pin 5 disconnected which is a big no-no. :eek:
    Try putting the recommended noise stopping capacitor from pin 5 to ground. The value is not ciritical, just a small greencap will do fine.
  4. Dodgydave
    Jun 22, 2012
    5,171
    778
    Sounds like pin 3 isn't going to full supply V+, i would put two extra 1N4001 diodes in series with Q1 base, or put a 1K resistor across its B/E terminals to help shut off..
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    I agree with Dodgydave. A resistor across the b/e pins should help.
    It won't on any 555 (unless it's a CMOS type).
  6. lost_bro
    Mar 17, 2009
    9
    Good Day Alec & Dodgydave
    Hit the nail on the Head!!!!
    Scoped pin#3: almost 1 volt difference (less) with Chinese NE555 than with old T.I. SA555.
    Not all chips created Equal!!!!!
    So, placed 1k between B & E on Q1 and now BOTH chips work fine!!!!
    Thanks for the assistance, you guys rock......
    lost_bro
    Alec_t and Dodgydave like this.
  7. lost_bro
    Mar 17, 2009
    9
    Hello The_RB
    Yes, you are correct, forgot to show that cap on the diagram.....
    thanks
    lost_bro
  8. lost_bro
    Mar 17, 2009
    9
    Good day GopherT
    Yes, after burping the tupperware _and_ adding a 1k between B&E on Q1, all works fine...... never forget to burp the tupperware;)
    lost_bro
  9. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    I'd say the old chip is out of spec.
    And you also used it out of spec.
    quite complicated circuit.
