S76477 Sound Chip Circuits Help
Discussion in 'General Electronics Chat' started by nickorossa, Aug 31, 2010.
  1. nickorossa
    Thread Starter Active Member
    Jun 28, 2010
    54
    Hi
    I'm finally looking at the details behind making use of the S76477 sound generator.
    Most of the circuits in the data sheet use a 2N3703 transistor as part of the output; however I'm unable to get them at my usual places. What would be a suitable alternative or is there simply a different part number for the transistor?
    http://docs.bgmicro.com/pdf/ics76477a.pdf
    Also what changes would be needed (if any) to use a 16ohm speaker rather than an 8ohm.
    Thanks.
    Nick.
  2. Jaguarjoe
    Apr 7, 2010
    770
    90
    A 2N3906 should work fine for you. Everybody sells them. FWIW- Futurelec sells the 3703 and the 3906.
    Looking at the circuit diagram, there is a 100 ohm resistor labelled "R loud"
    in series with the 8 ohm speaker and the driver transistor. To switch to a 16 ohm speaker you will need to make R loud 8 ohms less.
    nickorossa likes this.
