S video to av conversion
Discussion in 'General Electronics Chat' started by dlite elektroniks, Jul 14, 2014.
  1. dlite elektroniks
    Jul 14, 2014
    Do you wish to convert s-video to av? Its simple!!!
    Hold the s-video plug with the pins facing you. (note: S-video has four pins only). The two pins above are the positive rail and should be joined together on the reverse side (usually yellow and black). The two pins below are the negative rail and should be joined together on the reverse side (usually white and red). Thats it!!! Please note that you will have to connect your audio line seperately as this method does not transfer audio.
    I have tried it and i'm using my laptop with my tv set....its very easy
  2. timwhite
    Member
    Apr 10, 2014
    50
    7
  3. Ramussons
    May 3, 2013
    561
    92
    [​IMG][​IMG]
    Ramesh
