[S.T. - 10] Hybrid Amplifier - Common Emitter
Discussion in 'Homework Help' started by PsySc0rpi0n, May 11, 2015.
  1. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Hi once more.
    How do I find the Quiescent Point for an hybrid amplifier like the one attached? What do I do to the capacitors and Vsig??? For Small signal analysis we replace voltage sources by their internal impedance and the capacitors by short circuits. What about the Quiescent point?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. PsySc0rpi0n
    Mar 4, 2014
    1,191
    When we want to analyse this amplifiers, we use one of the various models available and our teacher calls it that way. The model we use, he calls it hybrid...
    Ok, that sounds better...
    So, I'm using Thevenin's theorem to simplify the circuit and write down the input and output net equations.
    So, using Thevenin I get:
    Vth = (Rb2*Vcc)/(Rb1 + Rb2) = (2*12)/(12)=2V
    Rth = Rb1//Rb2 = 1.67kΩ
    So, the input net equation would be:
    Vth + Rth*Ib + Vbe + Re*Ie = 0
    And the output equation would be:
    Vcc + Rc*Ic + Vce + Re*Ie = 0
    Assuming the transistor is in the active region, we can use currents relations to write those equations with only two unkowns like:
    Ie = ((hFE+1)/hFE)*Ic
    Vth + Rth*(Ic/hFE) + Vbe + Re((hFE+1/hFE)*Ic) = 0
    Vcc + Rc*Ic + Vce + Re*((hFE+1/hFE)*Ic) = 0
    From here I can calculate Ic and Vce to answer to the Q-Point.
    Is this correct?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    But hybrid - pi is a small-signal equivalent (replacement) model for transistor alone, not for the amplifier itself.
    At first glance everything look OK.
  5. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, aside from the names, I need to move on but using those equations I'm going to get a negative Vds. Is it correct?
    Edited;
    Ok, I did something wrong earlier today. I've re-checked my calcs and now my Q-point is (1.40V; 4.18mA).
    Can you help me confirm these values?
  6. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi Psy,
    If I follow your circuit correctly, it has a Collector resistor 2K2 and an Emitter resistor of 330R.??
    Use Ohms law to check Vc for [2k2 *Ic] and Ve for [330 * Ie] using your assumed Ic of 4.18mA...
    E
  7. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Morning Mr. EricGibbs.
    Yes, Rc = 2k2 Ω and Re = 330 Ω.
    So your saying to calculate Vc + Ve and check if this result is equal to Vcc? Is that it?
    PS: forgot to put a note in the first post saying that the Rpot is, for now, "out of the circuit"!
  8. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi,
    Not exactly, consider the Vc voltage at Ic.
  9. PsySc0rpi0n
    Mar 4, 2014
    1,191
    If I understood,
    Vc = Ic*Rc⇔Vc = 4.18*2k2 = 9.2V
    If it was this you were saying, I get 9.2V across Rc but I didn't followed your thought!
  10. ericgibbs
    Jan 29, 2010
    2,575
    389
    Dropping 9.2V across the 2200R would give a Vc of 12-9.2= 2.8V at 4.18mA
    If you considered a Ic value of say 3mA, that would give Vdrop = 2.2 * 3 = 6.6V , so Vc of 12-6.6 = 5.4V.
    The Hint I am trying to give you is what will be the Collector Load line voltage at the Q-point, how can it be 1.4V.?????
  11. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Well, I have used my calculator and used those 2 net equations to find Id and Vds and I think I don't like the results.
    Where x is Id and y is Vds.
    Shouldn't the Id current be positive sign?
  12. Jony130
    Feb 17, 2009
    3,990
    1,115
    OMG. Id and Vds in BJT ??
    Vth = Ib*Rth + Vbe + Ie * Re
    Ib = Ie/(Hfe +1)
    Vth = Ie/(Hfe +1)*Rb + Vbe + Ie * Re
    Vth - Ie/(Hfe +1)*Rb + Vbe + Ie * Re = 0
    Ie = (Vth - Vbe)/(Re + Rb/(Hfe +1) ) = (2V - 0.6V)/(0.33kΩ + 1.67kΩ/460) = 4.2mA
    Vc = Vcc - Ic *Rc = 12V - 4.2mA*10kΩ = -30V
    Also notice that for this circuit:
    Icmax = Vcc/(Re +Rc) = 12V/(10kΩ + 0.33kΩ) = 1.1mA
    All this means that your transistor is in saturation and Ic = Hfe*Ib do not hold anymore .
    So, you have chosen wrong operation point.
  13. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, I got confused somehow but is just a matter of names!
    Anyway, why do you go for Ib = Ie/(hFE + 1) and not Ib = Ic/hFE as we need Ic and Vce and not Ie or Ib????
  14. Jony130
    Feb 17, 2009
    3,990
    1,115
    Because I wanted to show you a alternative approach. Also notice that if we know Ie we eventually know all we want.
    Ib = Ie/(Hfe + 1) ; Ic = Ie * Hfe/(Hfe + 1) and because Hfe is very large in your example we can ignore Hfe/Hfe+1 and simply assume Ic = Ie (error will be smaller than 0.21%).
  15. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, I understood. But in our classes we always look for Vce and Ic. This will give us our Quiescent point. And when we use the output net equation and assume Ic = 0 we find Vce max and when we assume Vce = 0 we find Ic max. This two values allow us to draw the DC Load Line!
    So, I am still not finding correct results:
    Input net equation:
    Vth = Rth*Ib + Vbe + Re*Ie
    Vth = Rth*(Ic/hFE) + Vbe + Re*((hFE+1)/hFE)*Ic
    Ic = (Vth - Vbe)/(Rth/hFE + Re*((hFE+1)/hFE))
    Ic = (2 - 0.6)/(1.67/458.7 + 0.33*(459.7/458.7)) = 4.19mA
    Output net equation
    Vcc = Rc*Ic + Vce + Re*Ie
    Vce = Vcc - Rc*Ic - Re*((hFE+1)/hFE)*Ic
    Vce = 12-2.2*4.19 - 0.33*(459.1/458.7)*4.19 = 1.396V
    What is wrong with my calcs?
  16. Jony130
    Feb 17, 2009
    3,990
    1,115
    Ahh, your Rc is 2.2kΩ not 10kΩ. And why do you think that your calculations are wrong ?
  17. ericgibbs
    Jan 29, 2010
    2,575
    389
  18. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Well, because a few posts back, Mr. EricGibbs said that Vce couldn't be 1.4V. He did the following: Ic*Vc = 4.18*2.2 = 9.6V. Then Vcc - Vc = 12 - 9.2 = 2.8V so it could not be 1.4V.
  19. PsySc0rpi0n
    Mar 4, 2014
    1,191
  20. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi Psy,
    Have you read the link in my post #17.?
    Regarding Vce
    E
    EDIT:
    Not really.
    Think about what you are trying to determine for the Q point ie: Vcollector at the steady state collector current Ic.
