S-layer proteins and storage
Discussion in 'General Science' started by boks, Feb 1, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    An S-layer protein is 3nm is diameter. Calculate number of proteins per mm3 of membrane. If the
    protein is used to pattern a surface used for data storage - each protein molecule can position one
    magnetic particle (1bit) compare this type of storage with current hard disks.
    Just one question before I start calculating: Is it correct with "proteins per mm3 of membrane", or is it supposed to be "per mm2 of membrane", you think?
  2. fulcrum
    Feb 3, 2009
    I think you'll have to assume that a layer has the thickness of one protein.
  3. boks
    Oct 10, 2008
    218
    Takk, nydelig mann!
