Tha headlights on my motorhome are only getting 9v so I want to install relays to supply the full 12v. Along with the headlight supply I would also like to put in a ICC switch to flash the headlights at the truckers when they clear. So the relay will have 2 imputs on the dim side and 1 on the brights.
What relays would be good for this project and source for them? What size wire from the relay? Will it need any diodes? The only load on it will be the headlights, dim and bright.
I can get a good 12v supply.
Thanks for the help
JimJ
Thanks for the help
JimJ
