Running raspberry on laptop screen
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Jun 23, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have RPI2, model B with raspbian loaded on it.
    2. TO see the GUI, you have to connect a seprate monitor to RPI2 board.
    3. Is there anyway so that data can be viewed on laptop screen.
    because usually we carry laptop rather than monitor.
    4. One way is to get data out on uart terminal. But that is entirely terminal based.
    5. Also I have reading this:
    https://pihw.wordpress.com/guides/direct-network-connection/
    I am through all steps & can ping the laptop also. Able to set up connection by putty also.
    I am stuck in last step titled "Using X11 and Xming"
    Nothing happens when I run Xming, no screen opens.
  2. nsaspook
    Aug 27, 2009
    3,017
    2,378
    Can you ssh using putty from the laptop to the RPI?
    http://laptops.eng.uci.edu/instruct...ents/using-linux/how-to-configure-xming-putty
