Running a DC fan with AC.
Discussion in 'General Electronics Chat' started by dustiin, Mar 23, 2010.
  1. dustiin
    Jan 13, 2010
    60
    I've used the search function to no avail.
    I have a 12v 0.6amp PC fan that I plan on putting behind a radiator on a dirtbike. My bike delivers AC current, there's no rectifier or battery to change it. Whenever I hook up sufficient rectifiers up to the AC to turn it to DC the DC current gets high up to the 20volts line which I wouldn't want that to be connected to my 12v fan.
    I decided to hook the fan just straight up to my AC (which is regulated at 11.5-13.5v) and the fan spun pretty nicely like it was on this DC battery I hooked directly up to it.
    I'm wanting to know. Will it hurt for the fan to run on AC current in the long run?
    Thank you.
  2. retched
    Dec 5, 2009
    5,201
    313
  3. dustiin
    Jan 13, 2010
    60
    It's right underneath the fuel tank. The fuel tank is a thick plastic anyway.
    Well. If that's all I need is just a simple little solid state 12v regulator.
    Is it okay to run it on AC until my little piece arrives?
    Thanks again.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The regulator will smoke and burn if you feed it AC. It needs a DC input voltage that is at least 2V higher than its output.
