I found a motor in the "free" box at the local woodworking store. Broken was written on the side. When I removed the side cover I found a white run capacitor with a hole in the side. Two wires. The motor a single phase has two red wires and two white wires. What are the chances that the motor will work with a new capacitor? If so, how do I wire it into circuit? Or, should I put it back in the free box. Thanks
