I have a machine that has a control pad that uses rubber buttons, this are the ones that have a bit of conductive material on the end of it and it shorts two traces on the PC board.
One button dont work well if at all. I've cleaned the contact area on the PC board and the button. I also tested the contact pad and its fine.
I think I has seen kits to fix this somewhere, but I'm not sure if its just something to clean the contact pad.
I can't even Google it right because I can't even come up with the right term for this button.
thanks in advance
thanks in advance
