Hello All,
I have a set of RTR 180D Spkrs The Slave cabinet unit internal crossover cct has a press button reset style switch lablelled : littelfuse inc 230 815/series.
This appears to have gone open cct but I have no idea what it actually is or what I can replace it with.
CCT description::
One side of the BASE Spkrs are feed directly from the input socket, the other side from the output of the crossover network which is 15ohm ?? pot to 2 x 6uF Caps in Parallel to "Littelfuse Reset" to 2 x 5ohm 10W parallel resistors.
The tweeters are feed one side from Input Socket the other from the POT.
Any help greatly appreciated.
Rgds
TerryF
CCT description::
Rgds
TerryF
