Good morning,
I am currently in the process of building a circuit to excite an PRT (100 ohm @ 0 degC) with a constant current.
This current should be < 1mA and remain constant regardless of load resistance.
I have found two circuit designs;
The common method of using a bridge circuit will not provide adequete accuracy for the scope of the measurements.
Thanks in advance,
Peter
- I've seen the use of a LM317 but this seems to have a minimum current output of around 2 mA - do current regulators go lower than this?
- Otherwise I found a design which used two op-amps with a precision referance voltage (so a voltage regulator would be used instead) to generate the constant current.
Thanks in advance,
Peter
