I am using pic18f47j53 microcontroller.It has 1 RTCC pin.what to do with this pin?Is there any physical connections need to be done?According to my knowledge everything is to be done in programming.Please help..
I don't think that will be anything that you will need to worry about.• Alarm pulse or seconds clock output on RTCC pin
It sounds like you will not be using the real time clock calendar (RTCC) functions... so you need not do anything with that pin.I am using pic18f47j53 microcontroller.It has 1 RTCC pin.what to do with this pin?Is there any physical connections need to be done?According to my knowledge everything is to be done in programming.Please help..
It takes some skull sweat to choose no function?You are free to choose any ONE function for that pin. Choosing no function or more then one is possible but takes some skull sweat.
Yes it does. You mean you've never seen a thread devolve into a flame was about how to terminate an unused pin?It takes some skull sweat to choose no function?
First you spend an hour or 12 reading section 17.0 REAL-TIME CLOCK AND CALENDAR (RTCC) of the data sheet.How to configure that alarm indicator output..i.e what type of connections should be done on that RTCC pin??
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Duane Benson
