rtc problem pls help
Discussion in 'Embedded Systems and Microcontrollers' started by Gopi Vh, Jun 13, 2015.
  1. Gopi Vh
    Jun 13, 2015
    in the program below every thing is working fine including settings .the problem i am facing is when i am entering into setting of time rtc is stopped there and once i come back from setting its getting on. for eg if time is 12:15:42 and i am going to setting menu and i ll be there for say 2 mins and once i exit from that without changing any time den rtc ll start again from 12:15:43. if there any problm in code help me.sorry i could not attach file so i am putting my code below
    Code ( (Unknown Language)):
    1.
    2.
    3. // Lcd module connections
    4. sbit LCD_RS at LATB5_bit;
    5. sbit LCD_EN at LATB4_bit;
    6. sbit LCD_D4 at LATB3_bit;
    7. sbit LCD_D5 at LATB2_bit;
    8. sbit LCD_D6 at LATB1_bit;
    9. sbit LCD_D7 at LATB0_bit;
    10.
    11. sbit LCD_RS_Direction at TRISB5_bit;
    12. sbit LCD_EN_Direction at TRISB4_bit;
    13. sbit LCD_D4_Direction at TRISB3_bit;
    14. sbit LCD_D5_Direction at TRISB2_bit;
    15. sbit LCD_D6_Direction at TRISB1_bit;
    16. sbit LCD_D7_Direction at TRISB0_bit;
    17. //End LCD connection*/
    18. sbit Soft_I2C_Scl at RC3_bit;
    19. sbit Soft_I2C_Sda at RC4_bit;
    20. sbit Soft_I2C_Scl_Direction at TRISC3_bit;
    21. sbit Soft_I2C_Sda_Direction at TRISC4_bit;
    22. sbit BUZZER at RB6_bit;
    23. char timeset(); //time
    24. char dateset();//date
    25. char dayset();//day
    26. char hourset();//hour
    27. char minset();//min
    28. char secset();//sec
    29. char dates1();//date
    30. char months1();//month
    31. char years();//year
    32. unsigned char BCD2LowerCh(unsigned char bcd);
    33. unsigned char BCD2UpperCh(unsigned char bcd);
    34. unsigned short read_ds1307(unsigned short address );
    35. void write_ds1307(unsigned short address,unsigned short w_data);
    36. unsigned char temp1, temp ,rr, sec, minute,hour,day, month,year,date,dates11,dater11,mon11,yr11,hour_11,min_11,sec_11,dater_11,mon_11,yr_11,y, sec_1, minute_1,hour_1,day_1, month_1,year_1,date_1;
    37. unsigned char dates, months, hours, minutes,days,b,up,timer11,hour11,time11,min11,sec11,aa1,aa2,aa3,bb,cc,x,sec1,min1,hour1,day1,date1,month1,year1;
    38.
    39. char * text  = "0";
    40. char * text0 = "00";
    41. char * text1 = "00";
    42. char * text2 = "00";
    43. char * text3 = "00";
    44. char * text4 = "0";
    45. char * text5 = "00";
    46. char days1[] = "SUN";
    47. char days2[] = "MON";
    48. char days3[] = "TUE";
    49. char days4[] = "WED";
    50. char days5[] = "THU";
    51. char days6[] = "FRI";
    52. char days7[] = "SAT";
    53.
    54. char timer[9];
    55. char ddater[11];
    56. char pus[3];
    57. sbit set  at RA0_bit;   //buttons
    58. sbit inc at RA1_bit;
    59. sbit dec at RA2_bit;
    60. sbit set1 at RA3_bit;
    61.
    62.
    63.
    64. void main()
    65. {
    66.   x=1;
    67.   TRISB.F6=0;
    68.   TRISA.F0=1;
    69.   TRISA.F1=1;
    70.   TRISA.F2=1;
    71.   TRISA.F3=1;
    72.   ADRESL  = 0;
    73.   ADRESH = 0;  // Configure AN pins as digital I/O
    74.   ADCON0=0;
    75.   ADCON1 = 0x0F;
    76.   ADCON2 =0;
    77.   CMCON =7;
    78.   PORTA =0;
    79.   PORTB =0;
    80.   PORTC =0;
    81.   BUZZER =0;
    82.
    83.   /*OSCCON  = 0x70;*/
    84.   //TRISA= 0;
    85.   TRISC=0xFF;
    86.   Lcd_Init();  // Initialize LCD
    87.   Lcd_Cmd(_LCD_CLEAR);  // Clear display
    88.   Lcd_Cmd(_LCD_CURSOR_OFF);  // Cursor off
    89.   Soft_I2C_Start();
    90.
    91.   do{
    92.   for(rr=0;rr<=2;rr++)
    93.   {
    94.   Lcd_Cmd(_LCD_CLEAR);  // Clear LCD
    95.   Lcd_Cmd(_LCD_CURSOR_OFF);
    96.   Lcd_Out(1, 1, "TIME:");
    97.   Lcd_Out(2, 1, "DATE:");
    98.   sec=read_ds1307(0X00); // read second
    99.   minute=read_ds1307(0X01); // read minute
    100.   hour=read_ds1307(0X02); // read hour
    101.   day=read_ds1307(0X03); // read day
    102.   date=read_ds1307(0X04); // read date
    103.   month=read_ds1307(0X05); // read month
    104.   year=read_ds1307(0X06); // read year
    105.
    106.   sec1=sec;
    107.   min1=minute;
    108.   hour1=hour;
    109.   day1=day;
    110.   date1=date;
    111.   month1=month;
    112.   year1=year;
    113.   write_ds1307(0x26,sec);
    114.   write_ds1307(0x27,minute);
    115.   write_ds1307(0x28,hour);
    116.   write_ds1307(0x29,day);
    117.   write_ds1307(0x30,date);
    118.   write_ds1307(0x2A,month);
    119.   write_ds1307(0x2B,year);
    120.
    121.   timer[0] = BCD2UpperCh(hour);
    122.   timer[1] = BCD2LowerCh(hour);
    123.   timer[2] = ':';
    124.   timer[3] = BCD2UpperCh(minute);
    125.   timer[4] = BCD2LowerCh(minute);
    126.   timer[5] = ':';
    127.   timer[6] = BCD2UpperCh(sec);
    128.   timer[7] = BCD2LowerCh(sec);
    129.   timer[8] ='\0';
    130.
    131.   ddater[0] = BCD2UpperCh(date);
    132.   ddater[1] = BCD2LowerCh(date);
    133.   ddater[2] ='/';
    134.   ddater[3] = BCD2UpperCh(month);
    135.   ddater[4] = BCD2LowerCh(month);
    136.   ddater[5] ='/';
    137.   ddater[6] = '2';
    138.   ddater[7] = '0';
    139.   ddater[8] = BCD2UpperCh(year);
    140.   ddater[9] = BCD2LowerCh(year);
    141.   ddater[10] = '\0';
    142.
    143.   Lcd_Out(1,6,timer);
    144.   Lcd_Out(2,6,ddater);
    145.
    146.   if(day ==1)
    147.   Lcd_Out(1,14,days1);
    148.   if(day ==2)
    149.   Lcd_Out(1,14,days2);
    150.   if(day ==3)
    151.   Lcd_Out(1,14,days3);
    152.   if(day ==4)
    153.   Lcd_Out(1,14,days4);
    154.   if(day ==5)
    155.   Lcd_Out(1,14,days5);
    156.   if(day ==6)
    157.   Lcd_Out(1,14,days6);
    158.   if(day ==7)
    159.   Lcd_Out(1,14,days7);
    160.   delay_ms(1000);
    161.   }
    162. //setting part
    163.
    164.
    165.   if(set==0)
    166.   {
    167.   b=1;
    168.   do
    169.   {
    170.   up=0;
    171.   Lcd_Cmd(_LCD_CLEAR);
    172.   lcd_out(1,1, "1:time 2:date");  delay_ms(500);
    173.   lcd_out(2,1, "3:day use sw2");
    174.   delay_ms(500);
    175.   if(inc ==0)
    176.   {  up=1;
    177.   for(up=1;up<5;)
    178.   {
    179.   Lcd_Cmd(_LCD_CLEAR);
    180.   switch(up)
    181.   {
    182.   case 1:  lcd_out(1,1, "1:time ");
    183.   delay_ms(500);
    184.   if(set == 0)
    185.   {
    186.   x = timeset();
    187.   up=4;
    188.   }
    189.   break;
    190.   case 2:  lcd_out(1,1, "2:date ");
    191.   delay_ms(500);
    192.   if(set == 0)
    193.   {
    194.   x=dateset();  up=4;
    195.   }
    196.   break;
    197.   case 3:  lcd_out(1,1, "3:day ");
    198.   delay_ms(500);
    199.   if(set == 0)
    200.   {
    201.   x=dayset();  up=4;
    202.   }
    203.   break;
    204.   case 4:
    205.   if(x==0)
    206.   {
    207.   sec_1=read_ds1307(0X00); // read second
    208.   minute_1=read_ds1307(0X23); // read minute
    209.   hour_1=read_ds1307(0X22); // read hour
    210.   day_1=read_ds1307(0X25); // read day
    211.   date_1=read_ds1307(0X21); // read date
    212.   month_1=read_ds1307(0X20); // read month
    213.   year_1=read_ds1307(0X24); // read year
    214.   }
    215.   else
    216.   {
    217.   sec_1=read_ds1307(0X26); // read second
    218.   minute_1=read_ds1307(0X27); // read minute
    219.   hour_1=read_ds1307(0X28); // read hour
    220.   day_1=read_ds1307(0X29); // read day
    221.   date_1=read_ds1307(0X30); // read date
    222.   month_1=read_ds1307(0X2A); // read month
    223.   year_1=read_ds1307(0X2B); // read year
    224.   }
    225.   write_ds1307(0x00,sec_1);
    226.   write_ds1307(0x01,minute_1);
    227.   write_ds1307(0x02,hour_1);
    228.   write_ds1307(0x03,day_1);
    229.   write_ds1307(0x04,date_1);
    230.   write_ds1307(0x05,month_1);
    231.   write_ds1307(0x06,year_1);
    232.   up=5;
    233.   break;
    234.   }
    235.   if(inc == 0)
    236.   up++;
    237.
    238.   b=0;
    239.   }
    240.   }
    241.
    242.   }while(b == 1);
    243.   }
    244.
    245. }while(1);  //
    246.
    247. }
    248. unsigned short read_ds1307(unsigned short address )
    249. {
    250. int dat;
    251. soft_I2C_Start();
    252. soft_I2C_Write(0xd0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
    253. soft_I2C_Write(address);
    254. soft_I2C_Start();
    255. soft_I2C_Write(0xd1); //0x68 followed by 1 --> 0xD1
    256. dat=soft_I2C_Read(0);
    257. soft_I2C_Stop();
    258. return(dat);
    259. }
    260.
    261. unsigned char BCD2UpperCh(unsigned char bcd)
    262. {
    263. return ((bcd >> 4) + '0');
    264. }
    265.
    266. unsigned char BCD2LowerCh(unsigned char bcd)
    267. {
    268. return ((bcd & 0x0F) + '0');
    269. }
    270. void write_ds1307(unsigned short address,unsigned short w_data)
    271. {
    272. soft_I2C_Start(); // issue I2C start signal
    273. //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
    274. soft_I2C_Write(0xD0); // send byte via I2C (device address + W)
    275. soft_I2C_Write(address); // send byte (address of DS1307 location)
    276. soft_I2C_Write(w_data); // send data (data to be written)
    277. soft_I2C_Stop(); // issue I2C stop signal
    278. }
    279. char timeset()
    280. {
    281.   Lcd_Cmd(_LCD_CLEAR);
    282.
    283.   lcd_out(1,1,"1:hour2:min3:sec");
    284.   delay_ms(500);
    285.   lcd_out(2,1,"use sw4");
    286.   delay_ms(500);
    287.   timer11=0;
    288.   for(timer11=0;timer11<4;)
    289.   {
    290.   if(set1 ==0)
    291.   timer11++;
    292.
    293.   switch(timer11)
    294.   {
    295.   case 1:  Lcd_Cmd(_LCD_CLEAR);
    296.   lcd_out(1,1, "1:hour ");
    297.   delay_ms(500);
    298.   if(set ==0)
    299.   {
    300.   hour_11=hourset();
    301.   write_ds1307(0x22,Dec2Bcd(hour_11));  return 0;
    302.   }
    303.   break;
    304.   case 2:  Lcd_Cmd(_LCD_CLEAR);
    305.   lcd_out(1,1, "2:min ");
    306.   delay_ms(500);
    307.   if(set ==0)
    308.   {
    309.   min_11=minset();
    310.   write_ds1307(0x23,Dec2Bcd(min_11));  return 0;
    311.   }
    312.   break;
    313.
    314.   case 3:  Lcd_Cmd(_LCD_CLEAR);
    315.   lcd_out(1,1, "3:sec");
    316.   delay_ms(500);
    317.   if(set ==0)
    318.   {
    319.   sec_11= secset();  write_ds1307(0x21,Dec2Bcd(sec_11));
    320.   return 0;
    321.   }
    322.   break;
    323.   }
    324.
    325. }
    326. return 1;
    327. }
    328. char dateset()
    329. {
    330.   Lcd_Cmd(_LCD_CLEAR);
    331.
    332.   lcd_out(1,1,"1:date2:mon3:yr");
    333.   delay_ms(500);
    334.   lcd_out(2,1,"use sw4");
    335.   delay_ms(500);
    336.   timer11=0;
    337.   for(timer11=0;timer11<4;)
    338.   {
    339.   if(set1 ==0)
    340.   timer11++;
    341.
    342.   switch(timer11)
    343.   {
    344.   case 1:  Lcd_Cmd(_LCD_CLEAR);
    345.   lcd_out(1,1, "1:date ");
    346.   delay_ms(500);
    347.   if(set ==0)
    348.   {
    349.   dater_11= dates1();
    350.   write_ds1307(0x21,Dec2Bcd(dater_11));  return 0;
    351.   }
    352.   break;
    353.   case 2:  Lcd_Cmd(_LCD_CLEAR);
    354.   lcd_out(1,1, "2:mon ");
    355.   delay_ms(500);
    356.   if(set ==0)
    357.   {
    358.   mon_11 = months1();
    359.   write_ds1307(0x20,Dec2Bcd(mon_11));return 0;  }
    360.   break;
    361.
    362.   case 3:  Lcd_Cmd(_LCD_CLEAR);
    363.   lcd_out(1,1, "3:yr ");
    364.   delay_ms(500);
    365.   if(set ==0)
    366.   {
    367.   yr_11= years();  write_ds1307(0x24,Dec2Bcd(yr_11));
    368.   return 0;
    369.   }
    370.   break;
    371.   }
    372.
    373. }
    374. return 1;
    375. }
    376. char dayset()
    377. {
    378. unsigned char day_11;
    379. day_11=0;
    380. day_11=day1;
    381.   Lcd_Cmd(_LCD_CLEAR);
    382.   lcd_out(1,1," inc sw2  dec sw3"); delay_ms(500);
    383.   for(;day_11<=7;day_11)
    384.   {
    385.
    386.   if(inc  == 0)
    387.   day_11++;
    388.   if(dec ==0)
    389.   {
    390.   day_11--;
    391.   }
    392.   switch(day_11)
    393.   {
    394.   case 1: lcd_out(1,1,"sun");  delay_ms(500);
    395.   break;
    396.   case 2: lcd_out(1,1,"mon");delay_ms(500);
    397.   break;
    398.   case 3: lcd_out(1,1,"tue"); delay_ms(500);
    399.   break;
    400.   case 4: lcd_out(1,1,"wed");  delay_ms(500);
    401.   break;
    402.   case 5: lcd_out(1,1,"thu"); delay_ms(500);
    403.   break;
    404.   case 6: lcd_out(1,1,"fri"); delay_ms(500);
    405.   break;
    406.   case 7: lcd_out(1,1,"sat"); delay_ms(500);
    407.   break;
    408.   }
    409.   if(set == 0)
    410.   {
    411.   write_ds1307(0x25,Dec2Bcd(day_11));
    412.   return 0;
    413.   }
    414.   }
    415.   return 1;
    416. }
    417. char hourset()
    418. {  Lcd_Cmd(_LCD_CLEAR);  lcd_out(1,1," inc sw2  dec sw3");
    419.   delay_ms(500);
    420.   hour11=0;
    421.   hour11=hour1;
    422. for(;hour11<25;)
    423.   {
    424.
    425.   if(inc  == 0)
    426.   hour11++;
    427.   if(dec ==0)
    428.   hour11--;
    429.   pus[0]= hour11/10+48;
    430.   pus[1]= hour11%10+48;
    431.   pus[2]='\0';
    432.   Lcd_Cmd(_LCD_CLEAR);
    433.   lcd_out(1,1,"hour:");
    434.   lcd_out(1,6,pus);
    435.   delay_ms(500);
    436.   if(set == 0)
    437.   return hour11;
    438. }  }
    439.
    440. char minset()
    441. {  Lcd_Cmd(_LCD_CLEAR);
    442.   lcd_out(1,1," inc sw2  dec sw3");delay_ms(500);
    443.   min11=0;
    444.   min11=min1;
    445.   for(;min11<60;)
    446.   {
    447.   if(inc  == 0)
    448.   min11++;
    449.   if(dec ==0)
    450.   min11--;
    451.   pus[0]= min11/10+48;
    452.   pus[1]= min11%10+48;  pus[2]='\0';
    453.   Lcd_Cmd(_LCD_CLEAR);
    454.   lcd_out(1,1,"min:");
    455.   lcd_out(1,6,pus);  delay_ms(500);
    456.   if(set  == 0)
    457.   return min11;
    458. }
    459. }
    460. char secset()
    461. {  Lcd_Cmd(_LCD_CLEAR);
    462.   lcd_out(1,1,"inc sw2 dec sw3");  delay_ms(500);
    463.   for(sec11=0;sec11<60;sec11)
    464.   {
    465.   if(inc  == 0)
    466.   sec11++;
    467.   if(dec ==0)
    468.   sec11--;
    469.   pus[0]= sec11/10+48;
    470.   pus[1]= sec11%10+48;  pus[2]='\0';
    471.   Lcd_Cmd(_LCD_CLEAR);
    472.   lcd_out(1,1,"sec:");  delay_ms(500);
    473.   lcd_out(1,6,pus);
    474.   if(set  == 0)
    475.   return sec11;
    476.   }
    477. }
    478. char dates1()
    479. {  Lcd_Cmd(_LCD_CLEAR);
    480.   lcd_out(1,1," inc sw2  dec sw3");delay_ms(500);
    481.   dater11=0;
    482.   dater11=date1;
    483.   for(;dater11<32;)
    484.   {
    485.   if(inc  == 0)
    486.   dater11++;
    487.   if(dec ==0)
    488.   dater11--;
    489.   pus[0]= dater11/10+48;
    490.   pus[1]= dater11%10+48;  pus[2]='\0';
    491.   Lcd_Cmd(_LCD_CLEAR);
    492.   lcd_out(1,1,"date:");  delay_ms(500);
    493.   lcd_out(1,6,pus);  delay_ms(500);
    494.   if(set  == 0)
    495.   return dater11;
    496. }
    497. }
    498. char months1()
    499. {  Lcd_Cmd(_LCD_CLEAR);
    500.   lcd_out(1,1," inc sw2  dec sw3");delay_ms(500);
    501.   mon11=0;
    502.   mon11=month1;
    503.   for(;mon11<12;)
    504.   {
    505.   if(inc  == 0)
    506.   mon11++;
    507.   if(dec ==0)
    508.   mon11--;
    509.   pus[0]= mon11/10+48;
    510.   pus[1]= mon11%10+48;  pus[2]='\0';
    511.   Lcd_Cmd(_LCD_CLEAR);
    512.   lcd_out(1,1,"mon:");  delay_ms(500);
    513.   lcd_out(1,6,pus);  delay_ms(500);
    514.   if(set  == 0)
    515.   return mon11;
    516. }
    517. }
    518. char years()
    519. {  Lcd_Cmd(_LCD_CLEAR);
    520.   lcd_out(1,1," inc sw2  dec sw3");  delay_ms(500);
    521.   yr11=0;
    522.   yr11=year1;
    523. for(;yr11<99;)
    524.   {
    525.
    526.   if(inc  == 0)
    527.   yr11++;
    528.   if(dec ==0)
    529.   yr11--;
    530.   pus[0]= yr11/10+48;
    531.   pus[1]= yr11%10+48;  pus[2]='\0'; Lcd_Cmd(_LCD_CLEAR);
    532.   lcd_out(1,1,"year:");  delay_ms(500);
    533.   lcd_out(1,6,pus);  delay_ms(500);
    534.   if(set  == 0)
    535.   return yr11;
    536. }
    537. }
    538.
    539.
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    I can't follow the structure of your code so here's a general answer:
    Make a dirty_flag that is set false when you enter the setting function and only set when and if anything is changed.
    Then test the flag before you do an update.
