Rs485 to Ethernet & ethe to rs485
Discussion in 'General Electronics Chat' started by vahidsadri2000, Apr 11, 2012.
  1. vahidsadri2000
    Apr 11, 2012
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Your post was moderated because you did not attach the images locally. When using images and zip files AAC prefers you to attach them locally.
    Your image was way oversized so I resized it to allow it to fit on the screen.
  3. djsfantasi
    Apr 11, 2010
    2,911
    881
    Note that the standard calls for a maximum distance of 120m for 100Base-T cables. The RS485 standard calls for a maximum distance of 1200m. I suggest that you use RS485 communications between your PC and MYBOARD.
    Converting from RS485 to ethernet actually is a reduction in the distance you can achieve. Unless you plan on routing over the Internet... which has its own sets of problems. (On the other hand, RS232 calls for a maximum distance of only 15m)
    strantor and vahidsadri2000 like this.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    yes, I was scratching my head on this. RS485 is used in industrial settings to transmit very long distances; much further than ethernet. RS485 should be used IMO.
    A solution I have seen is fiberoptics. Check out Siemens OLM; it will convert your rs485 to fiberoptic, and then back into RS485
